[GRASSLIST:5436] Newcomer Q:Missing libraries on OS X
I am trying to install GRASS, and have used the GRASS complete download for OS X from http://wwwamb.bologna.enea.it/forgrass/download.htm
but I don't know if my libraries have been installed; I can't find a grasslib folder on my computer anywhere.
I don't know if GRASS is working right or not because I am new, but in the tutorial it crashes when trying to import .shp files.
Thank you in advance,
Matt Sakals, PAg, GIT
Sustainable Forest Management Laboratory
University of British Columbia
mailto:msakals@interchg.ubc.ca
http://sustain.forestry.ubc.ca/home.html
__________________________________
I am having problems with rasters after doing an update in GRASS 57:
r.mapcalc mapa2=mapa1*4
ERROR:G_open_raster_new: no temp files available
after that i update also the gdal library but it does not work
thank you in advance
Marta
On 1/19/05 8:30 AM, “Matt Sakals” msakals@interchange.ubc.ca wrote:
but I don’t know if my libraries have been installed; I can’t find a grasslib folder on my computer anywhere.
Matt,
If you have run the install program for the grass libraries in Lorenzo Moretti’s GRASS complete, they are probably OK. They are located in /usr/local/grasslib. This is a ‘hidden’ directory on a Mac. You can check it by either…
  1. Using the terminal program and entering
cd /usr/local/grasslib
ls
  1. Selecting ‘Go to folder’ from the ‘Go’ menu in the finder. Enter /usr and press ‘Go’
    You should be able to navigate to /usr/local/grasslib then.
I don’t know if GRASS is working right or not because I am new, but in the tutorial it crashes when trying to import .shp files.
You don’t say which version of GRASS you are using. But I recommend using GRASS 6.0.0beta1. It is posted on my mirror site for Lorenzo’s files. I do NOT recommend using 5.7.0 because it is problematic. GRASS 5.4 is fine also, but 6.0 does more and generally does it more better. You should have no trouble importing a *.shp file using v.in.ogr in GRASS 6.0.
Hope this helps.
Michael
C. Michael Barton, Professor of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
