I've been trying to export an arc/info ungenerate file (polygons only) for a
vector file that contains 50084 areas. The resulting files when I call
v.out.arc vect=veglayer.stand type=polygon arc_prefix=veglayer.stand
are the same as when I call
v.out.arc vect=veglayer.stand type=line arc_prefix=veglayer.stand
I've made sure I've build topology for the file and can't see how I'm doing
anything wrong. I've been using my compiled version of GRASS5.0.1 and can't
recall if this was the case using 5.0.0
Jeff.
