-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Markus Neteler wrote:
|>Hash: SHA1
|>Hi,
|>I am using Grass 5.4.0 for Arm Linux Handheld.
|>I compiles the Grass And Baby Grass for arm-linux and loaded to handheld.
|>but when i run the grass54, it ask for file g.gisenv
|>in the grass54 bin folder.
|>unfortunatly the files is not found after compiling ?
|>for the native machine it work fine.
|>So,
|>1. Can any one tell me, how can i compile only these file for
|>arm-linux-gcc ?
|>2. The File grass54/etc/clean_temp
|>3. The File grass54/etc/run
|>are also not present.
| It may be possible (can't remember and away from the office
| machine now) that the desired modules have to be included
| into the babyGRASS source code.
| Just add the relevant directories to
| handheld/babyGRASS_packagingsrc.sh
| package and compile again.
| Good luck
| Markus
Dear Markus
Yes you are correct, I check that,
The modules is also there. in the sh file and when we run .configure
as
export CC=arm-linux-gcc
export CPP=arm-linux-c++
export C77=arm-linux-c77
CFLAGS="-I/opt/simputer/include -I/opt/simputer/arm-linux/include
- -L/opt/simputer/lib/ -L/opt/simputer/arm-linux/lib/" CC=arm-linux-gcc &&
../babyGrass_src/configure --prefix=/opt/simputer
- --exec-prefix=/opt/simputer --build=Simputer --host=arm-linux
- --target=arm-linux --x-includes=/opt/simputer/include/X11/
- --x-libraries=/opt/simputer/arm-linux/lib/X11/
- --with-gtk-prefix=/opt/simputer/gtk1.2/
- --includedir=/opt/simputer/include/ --libdir=/opt/simputer/lib
- --without-fftw --without-proj --with-cxx=yes --without-tiff
- --without-tcltk --without-postgres --without-opengl --without-odbc
The Module folder is get copied in src\general\g.gisenv and on
runing make the file main.o get created in src\general\g.gisenv
but We will not get out the g.gisenv as excutable.
It give out as error in error.log
Compilation error in module: src/general/g.gisenv
There are some many other files.. on this.
Remeber :
On Native Linux 9.0 it is working 100% fine.
I am trying to compile it for Arm-Linux
TO Know:
Do the application need the processor for gcc only ?
Do this module run on only native.
http://www.force3-india.org/downloads/Technology/GRASS_conf_2002.pdf
You Can access the Error Log and Compiles srcipts as
http://www.force3-india.org/downloads/Grass/
Thanks in Advance
Waiting for reply.
Regards, and Have a nice day.
Prachait Saxena
Force3 Team
(M) :- +91 98229 44025
(M) :- +91 93732 81318
(E) :- prachait (at) force3-india (dot) com
(E) :- subscription (at) force3-india (dot) com
(W) :- http://www.force3-india.org/
_________________________________
Our Solution at Microsoft Solution Market Place
Public Grievance Redressal System version 1.0.0
http://www.microsoft.com/asia/solutionmarketplace/solutiondetail.asp?ind=3&sid=30101&type=1&solid=1760&language=1&searchresult=true&sLanguage=1
Checkout Latest:
http://force3-india.org/downloads/Presentations/Force3-India_inCLASS-Presentation.zip
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.0 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFB8qBZj59Y6fbuGH0RAtQAAKDl/E+5wJ3+E2K5bhUz9kNe6JKLaQCcCHJ+
xInhFyNb8zJ8UNNg4bJYTeQ=
=LyYK
-----END PGP SIGNATURE-----
