[GRASSLIST:5556] v.in.e00, v.in.ogr problems
Howdy all,
I'm new to GRASS coming from an ESRI background. As such, I have quite a few coverages and resultant
.e00 files to bring into GRASS. Most of the coverages were created on a Solaris/UNIX box though some
were created on Windows box. I'm trying to bring these onto a Mac running 10.3.x with the Grass 6.0beta
binary install.
At first I was trying to import the .e00 files directly using v.in.e00. I've seen on the list that there is a bit of a
problem with that. Therefore, I used AVCIMPORT to generate coverages. The problem now is that when
using v.in.ogr with the coverages, I get an ERROR: Cannot open data source.
Mapset <scale100k> in Location <US_dd_NAD83>
GRASS 6.0.0beta1 > v.in.ogr dsn=/volumes/wooster/test/rail1 output=rail layer=ARC type=line
I originally thought it might be a permissions problem. However, I opened all directories and files to 777
with the same result.
The odd thing is that v.in.ogr works fine with coverages created on the Windows box.
Any thoughts would be appreciated.
Harry Johnson
source.
are you sure that you are using dsn and layer correctly?
for shape files, dsn should be the directory where data is and layer
should be the name of the shape file (without the .shp extension).
is your import filename really called ARC.shp?
Hamish
I believe so. I was following the example for Arc/Info coverages.
I made dsn the coverage directory (rail1), and layer to the feature I wished
to import (Arcs/lines).
I'm a bit odd in that I don't really like the shapefile format and prefer to use
coverages and topology.
I'm looking into some other ideas, like making sure the coverages actually
had topology before I generated the .e00 files, the method of transfer (the .e00
files being tar'ed up on Solaris and untar'ed on OS X), UNIX line ends v. Windows
line ends, and of course, my general thick-headedness.
Harry Johnson
source.
Hamish
This error comes after it tries to read dsn=
this one?
http://grass.ibiblio.org/grass60/manuals/html60_user/v.in.ogr.html
what files does 'avcimport' produce?
correct.
and layer to the feature I wished to import (Arcs/lines).
layer should be the shape file name (without the extension),
e.g. rail.shp, not what is in it.
This should list available layers:
v.in.ogr -l dsn=... output=test
        (-l is a lower case "L" not a one)
what file names are in /volumes/wooster/test/rail1 ?
For shape file input should be *.shp *.shx *.dbf *.sbn *.sbx (*.prj)
You might try viewing the shape files with other software, e.g.:
JUMP http://www.jump-project.org/project.php?PID=JUMP&SID=OVER
QGIS http://qgis.sourceforge.net
to find out if the files are ok.
Hamish
