[GRASSLIST:5621] Libraries
Grass users,
After a 2 year absence. I recently rejoined the grass community and downloaded the binary Generic Gnu/linux versions of the stable 5.4.0 and the development 6.0. I am running mandrake 10 linux and my question is where do i get the needed libraries:
  libpq, libproj, libgdal , xterm, tcl, tk, gdaltools, libfftw, etc.
or more precisely how would I now it they are already installed, where should i look for and if they are not installed, where/how do I get them.
It is nice to be using grass again.
Best regards
Alejandro Hinojosa
Geology Department ,Earth Sciences Division
CICESE
P.O. Box 434843
San Diego Ca. 92143-4843
Phone + 52 646 175-0500 ext 26045
Fax + 52 646 175-0557
                          175-0559
them.
links on this page:
http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/grass51/REQUIREMENTS.html
I do not know which Mandrake packages supply these; there used to be a
GRASS package in the Mandrake cooker, maybe check that for dependancies.
(or someone else knows)
Hamish
them.
links on this page:
Hamish
I work on Mandrake 10.1.
Check if are installed via the rpmdrake uninstall GUI. If are available for
install - via the the install GUI.
Some of those packages you mention will be available if you setup an ftp
contrib repository (urpmi.addmedia or again rpmdrake appropriate GUI). If
you don't have a reasonable net connetction, like me :(((, you can download
the whole contrib once you put your hands on a fast net and burn the suff on
a DVD and, again, use urpmi.addmedia on it. If no DVD recorder at hand, like
in my case :(((, but not for long :))), you can still use CDs - portion the
contrib stuff into ~700MB bids (*only* the rpms in that case, omit all the
syntheses etc.), should be 5 or 6 discs, and burn. Add each to urpmi
database with urpmi.addmedia --no-probe. All the emerging dependences will
be automatically solved including these new repositories.
And if you wish to build from source and frequently update you Linux GIS
stuff from CVS, a good idea is checkinstall (you'll need to install it first
from a contrib repository; I don't know abou 10.0 but for 10.1 it is availbale) instead of "make install". It automaticaly builds rpms (and debs if needed) from the "make" output - so you'll be able to manage your programs easily with rpm command. Works nice so far with all Grass, Gdal, GEOS, Qgis, Hdf4 and Proj versions I tried.
Good luck!
Maciek
