I have been working with Grass 6.0 to try to output elevation values from a
raster map at specific intervals from coordinates. I have been sucessful at
getting coordinates into Grass. However, I have not found a way to create
buffers or concentric circles that overlap and maintain the centroid
attribute. I want to have the circles in miles (like in the raster buffer)
rather than map units (like in the vector buffer). I am willing to try to
write code for a solution, but I have limited experience.
Does anyone have a suggestion for how I should approach this task?
Thanks for taking the time to read this message, and for briefly thinking
about it.
Nathan
Nathan Wales wrote:
I have been working with Grass 6.0 to try to output elevation values from a raster map at specific intervals from coordinates. I have been sucessful at getting coordinates into Grass. However, I have not found a way to create buffers or concentric circles that overlap and maintain the centroid attribute. I want to have the circles in miles (like in the raster buffer) rather than map units (like in the vector buffer). I am willing to try to write code for a solution, but I have limited experience.
Thanks for taking the time to read this message, and for briefly thinking about it.
Nathan
You have to overlay individual buffers in loop, for example:
v.in.ascii -e output=buffers
for C in 1 2 3
do
v.extract input=points output=point list=$C
v.buffer input=point output=buffer
v.overlay -t ainput=buffers binput=buffer \
output=tmp olayer=0,1,1
g.copy vect=tmp,buffers
done
Radim
