[GRASSLIST:5873] Re: projection, color rules for vectors
> I wanted to display a map of Germany (5E-16E, 47N-56N) using Universal
> Polar Stereographic projection and wgs84 ellipsoid, but it is still
wider
> than higher. I tried the lat-lon projection before, but the result was
the
> same. Actually, on most commercial general maps of Germany, the
country is
> "almost the same wide as tall", while all these projections show it
much
> wider. Which projection/ellipsoid would you recommend for usage on
such
> location as Germany?
Have you tried Gauss-Krüger ?
Yes, but it is always the same. I have tried this:
http://freegis.org/freegis_tutorial/online/node39.html
I've created a new location/mapset with tmerc projection and bessel
ellipsoid, then imported the raster map of elevation in Germany and
painted it. I'm attaching the output PNG for you (you see it is too wide,
for example the Czech republic at the Eastern edge of the map should look
more like a square - delimited by three yellow mountain ranges). I think
it shouldn't depend on the raster map (I downloaded it from some free gis
server), so there is a problem in grass (of course it comes from between
the chair and keyboard, but as I told you, I don't know too much about
projections and their implementation in grass).
I'm sorry, but I'm no expert on German projections. Maybe someone else can
help ?
Moritz
