[GRASSLIST:5875] How to Create Proportional Symbols for Concentrations?
I've managed to import a dbf table of PAH concentrations for sample
locations into Grass 6.0 using db.connect driver=dbf and then v.in.db
x=Longitude y=Latitude key=PAH_ppm. Is there a way to symbolize the vector
points so that their sizes are proportional to their concentration values?
~ Eric.
vector points so that their sizes are proportional to their
Sure, use 'd.vect.chart ctype=pie sizecol=' with only one data column.
Alternatively use d.vect or v.buffer+v.patch looped in a script?
Hamish
