NOTE: Respond directly via-e-mail as listed above please
error
$ startxgrass.bat
xmodmap: unable to open file ‘/etc/X11/Xmodmap.127.0.0.1’ for reading
xmodmap: 1 error encountered, aborting.
using:
startxgrass.bat
os:
win xp
cygwin
xwin
x11r6 lib
setup:
c:\os\cygwin\usr\local\grass5
status:
text based grass works
text base to tcltk& works
xwindows port does not work properly
what I’ve tried
I tried manualy moving grass/etc/x11 dir to c:\lang\etc\x11 but the system still hangs, but the xwin windows pop up for the GISDBASE/LOCATION… screen
re-installed xfree86 files from cygwin setup… nothing happened
changed 's to /'s cause I thought there might be a error (that messed things up more of course)
tried running startxwingrass.bat from the home dir c:\os\cygwin\home\d400s
it failed due to not finding xwin32…
I did a search and only found xwin.exe no xwin32
any ideas… any experieince
