You need a postgres user and a postgres group on your system. For some reason the MySQL install (via Fink) creates the necessary user and group for itself, but Postgres doesn't.
If you have Mac OS X 10.2 or later, you can just add a line to your /etc/group file.
postgres:*:71:
The group number 71 works on my system, but if there's already a 71 in the group file, choose an unused number.
To add the user postgres, run sudo vipw. You get to edit the passwd file with vi.
Add something like
postgres:*:71:71:Postgresql Server:/nohome:/noshell
Again, if 71 is taken, use something else.
If you can't figure out vi, or don't have Jaguar, you're stuck with adding the user and group in NetInfo (/Applications/Utilities/NetInfo Manager)
Good Luck
Dave
On Tuesday, April 8, 2003, at 04:01 PM, John Chesnut wrote:
Can some one who has experience getting Postgres interoperating with Grass on Mac OSX please post step by step instructions.
The initdb command will create a "data" directory, but the postgres server fails on startup. The initdb command requires su as the "postgres" user
su postgres
/usr/local/pgsql/bin/initdb -D /usr/local/pgsql/data
complete successfully.
Several issues are apparent
1. Postmaster does not successufully start using the terminal command postmaster (eg.
sudo -u postgres /usr/local/pgsql/bin/postmaster -i -D /usr/local/pgsql/data
this reports the error
FATAL: no such group 'pgsql'
/usr/local/pgsql/bin/postmaster: cannot create UNIX stream port
my interpretation: some parts of postmaster need write permission with group pgsql which is not created by MacOSX
2, attempting to open the postmaster with the command
sudo -u pgsql /usr/local/pgsql/bin/postmaster -i -D /usr/local/pgsql/data
yield the error
FATAL 1: cannot open /usr/local/pgsql/data/PG_VERSION: Permission denied
my interpretation: requires read permission of user "postgres" which is lacking for user pgsql
(I created the alternative user pgsql in an attempt to start postmaster)
3. attempting to start postmaster using the pg_ctl script as either user postgres or pgsql yields a similar error.
sudo -u root sudo -u pgsql /usr/local/pgsql/bin/pg_ctl start -D /usr/local/pgsql/data
this returns a message
postmaster successfully started
same error as 2.
Evidently getting the postmaster/postgres server running need alterations of permissions and groups, but no documentation is available that explains how to create a "pgsql" group and associate it with a "postgres" user.
Changing the /usr/local/pgsql/data directory permissions to 777 or 766 yields an fatal error that permissions are incorrect: so simply expanding permissions doesn't work. The error reported is:
FATAL 1: data directory /usr/local/pgsql/data has group or world access; permissions should be u=rwx (0700)
trying to create a user from within postgres as in
sudo -u postgres /usr/local/pgsql/bin/createuser jchesnut
fails because
psql: could not connect to server: No such file or directory
Is the server running locally and accepting
connections on Unix domain socket "/tmp/.s.PGSQL.5432"?
my interpretation: postmaster / postgres must be running before the createuser command can be issued. postgres wont run because of the fatal errors listed above.
Please help, if you know how to get postgres running under OSX
