[GRASSLIST:6116] Grass 5.0.2 RPMS for Mandrake 9.1
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Just a note that there are updated Grass RPMs available for Mandrake 9.1
on my site. You should be able to install as follows:
# urpmi \
http://ranger.dnsalias.com/mandrake/9.1/grass-5.0.2-1mdk.i586.rpm
If you want to ensure that you keep the RPM (after all it is 36MB),
either download seperately and open the RPM with "Software Installer"
(from Konqueror/Nautilus etc) or use urpmi on the file, or run:
# urpmi --noclean \
and fish it out of /var/cache/urpmi/rpms before you run urpmi again.
Of course, these update the RPMS of 5.0.0 which are in contribs for 9.1.
The 5.0.0 RPMS from contrib are also available in the boxed sets of
Mandrake 9.1 (only PowerPack and ProSuite).
All dependencies are in contribs for 9.1, if you don't know what contrib
is, run:
# urpmi urpmi.setup
# urpmi.setup
And you should be able to find a contrib mirror near you.
The SRPM used for this build is identical to the current cooker SRPM.
Buchan
|--------------Another happy Mandrake Club member--------------|
Buchan Milne Mechanical Engineer, Network Manager
Cellphone * Work +27 82 472 2231 * +27 21 8828820x121
Stellenbosch Automotive Engineering http://www.cae.co.za
GPG Key http://ranger.dnsalias.com/bgmilne.asc
1024D/60D204A7 2919 E232 5610 A038 87B1 72D6 AC92 BA50 60D2 04A7
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.1 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQE+prMJrJK6UGDSBKcRAqeHAJ4zqUkU4XP1Mt5Qea9KpdwSVoBk9gCdGriT
ArExTZkmrLFA5ZKZuK0qmxs=
=b703
-----END PGP SIGNATURE-----
