[GRASSLIST:6136] RE: NVIZ problem
dear Markus,
both suse 8.1 as 8.2 do deliver version 8.4 of tcl.
possibly related to this newest version I met other problems, with which I
was not confronted while installing grass5.0.0 under suse 7.2.
grass.postgresql does not compile ...
./configure --with-postgres-includes=/usr/local/pgsql/include --with-postgre
s-libs=/usr/local/pgsql/lib --with-dbm --with-
gdal=/home/nico/gdal-1.1.8 --with-freetype --with-freetype-includes=/usr/inc
lude/freetype2 --with-freetype-libs=/usr/lib
  resulting in:
  GRASS is now configured for i686-pc-linux-gnu
      Source directory: /home/nico/grass5.0.2
      Build directory: /home/nico/grass5.0.2
      Installation directory: /usr/local/grass5
      C compiler: gcc -g -O2
      FORTRAN compiler: g77
      NVIZ: yes
      X11 support: yes
      DBM support: yes
      JPEG support: yes
      TIFF support: yes
      PNG support: yes
      GD support: yes
      Tcl/Tk support: yes
      PostgreSQL support: yes
      OpenGL(R) support: yes
      ODBC support: yes
      FFTW support: yes
      BLAS support: no
      LAPACK support: no
      Motif support: no
      FreeType support: yes
      GLw support: no
      NLS support: no
      Readline support: no
  make 2>&1 | tee compileOutput.log
  error.log:
    GRASS GIS source code compiled.
    Compilation error in module: src/misc/m.kappa (ignored)
    Compilation error in module: src/raster/r.in.doq (ignored)
    Compilation error in module: src/raster/wildfire (ignored)
    Compilation error in module: src.garden/grass.postgresql (ignored)
  part of compileOutput.log with the grass.postgresql - errors:
    /home/nico/grass5.0.2/src.garden/grass.postgresql/g.column.pg
      mkdir OBJ.i686-pc-linux-gnu
      make -f OBJ.i686-pc-linux-gnu/make.rules
    make[2]: Entering directory
`/home/nico/grass5.0.2/src.garden/grass.postgresql/g.column.pg'
cc -I/home/nico/grass5.0.2/src/include -g -O2 -I/usr/local/pgsql/include -
Wall -DPACKAGE=\""g.column.pg"\" -c main.c -o
OBJ.i686-pc-linux-gnu/main.o
    main.c:83:30: missing terminating " character
    main.c: In function `main':
    main.c:84: error: parse error before "a"
    main.c:85: error: stray '\' in program
    main.c:85:35: missing terminating " character
    main.c:87:37: warning: multi-character character constant
    main.c:91:34: missing terminating " character
    main.c:96:30: missing terminating " character
    main.c:97: error: parse error before "FROM"
    main.c:98:37: warning: multi-character character constant
    main.c:101:34: missing terminating " character
    /usr/include/stdlib.h: At top level:
    /home/nico/grass5.0.2/src/include/gis.h:35: warning: `GRASS_copyright'
defined but not used
    make[2]: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
    make[2]: Leaving directory
    make[1]: *** [all] Error 2
    make[1]: Leaving directory
`/home/nico/grass5.0.2/src.garden/grass.postgresql'
    GISGEN failure at STEP: src.garden/grass.postgredo g3d /SG4d not offer the
possibilty to study a 4th dimension (temp) within a 3d spatial
environment?sql
do you have any indication what goes wrong??
I also have problems while attaching pgaccess to the postgresSQL database I
don't know if this is a comparable problem with shared libraries - I'll
request the postgreSQL-list
  version 98.7:
    nico@laptop:/usr/local/pgaccess> ./pgaccess
    Error in startup script: couldn't load file "libpgtcl.so": libpgtcl.so:
cannot open shared object file: No such file or directory
        while executing
    "load libpgtcl[info sharedlibextension]"
        (procedure "main" line 3)
        invoked from within
    "main $argc $argv"
        (file "/usr/local/pgaccess/main.tcl" line 249)
  version 98.8:
    nico@laptop:/> pgaccess
    Parsing the command line parameters:
          Loading the cmdline package... FAILED
    Error: can't find package cmdline
    Please install the tcllib package
(http:://www.sourceforge.net/projects/tcllib)
    Error in startup script: invalid command name "cmdline::getopt"
        while executing
    "cmdline::getopt argv $getopt_list opt val"
        (procedure "parse_cmd_line" line 85)
        invoked from within
    "parse_cmd_line"
        (procedure "init" line 10)
        invoked from within
    "init $argc $argv"
        (file "/usr/X11R6/bin/pgaccess" line 736)
Additionally, I also want to use 3d voxel routines - g3d / SG3d / sg4d - and
have problems to get g3d compiled see mail "problem compiling g3d"
thanking in advance,
Nico
-----Oorspronkelijk bericht-----
Van: Markus Neteler [mailto:neteler@itc.it]
Verzonden: woensdag 23 april 2003 11:19
Aan: Nico Hardebol
Onderwerp: Re: [GRASSLIST:6105] RE: NVIZ problem
On Tue, Apr 22, 2003 at 02:42:23PM +0200, Nico Hardebol wrote:
I'm running the newest Suse linux 8.2 on dell laptop - but afterwards
downgraded the tcl/tk libraries to 8.3 (instead of 8.4)
which tcl/tk does Suse 8.2 deliver: 8.4.?
This is important to know as we probably have to add extra header
files to NVIZ.
This is a bug in g.column.pg. A string literal contains embedded
newlines; gcc used to allow this, but presumably the latest versions
don't.
Try the attached patch.
  version 98.7:
This isn't relevant to GRASS.
pgaccess is a Tcl/Tk program for accessing PostgreSQL databases.
libpgtcl is a Tcl/Tk extension which provides Tcl/Tk commands for
accessing PostgreSQL databases, and is required by pgaccess; no part
of GRASS needs it.
(attachments)
g.column.pg.patch (1.3 KB)
