[GRASSLIST:6416] make intermediate contours or any contours at all
I want to enter by hand contour lines of 100, 200, 300 meters,
and make a map with contours every 50 meters.
r.surf.contour says use v.digit. OK but then how does one put the
elevation in each label?
Do I run r.label three times or something?
And then I use v.to.rast, is that right?
And then r.surf.contour I suppose.
And then r.contour, and finally d.vect, no?
Let's say I fail because I can't understand instructions, and must
just draw everything by hand. I suppose I would still need to use
v.digit and somehow get the labels on the lines?
In v.digit, before digitizing, open up settings -> table tab and add
an elevation column, then create table. then add elevation as you
digitize lines.
Or if you want to tags to vector lines after you already have them in a
map, use db.execute to add a column and then 'd.what.vect -e' to label.
sounds right.
another way if you want to use splines is: v.to.points + v.surf.rst
see above.
I think you can use QGIS to do it as well.
Hamish
