[GRASSLIST:6576] gdal library for grass
Hi List
I have a problem compiling Gdal 1.2.6 with HDF4.2r1 support on Solaris-7-sparc,
and wonder if someone can assist me please. I hope to use this in Grass 6.
When I run GDAL configure, it complains it cannot find the hdf4 libraries.
These are actually present OK, the problem seems to really be a failure to find the routine SDreaddata that configure uses as a test case. Configure reports:
> checking for FMEObjects... no > checking for SDreaddata in -lmfhdf... no
> checking for SDreaddata in -lhdf4... no
> configure: error: HDF4 support requested with arg /usr/local/hdf4, but neither hdf4 nor mfhdf lib found
The libraries are present : ls -l /usr/local/hdf4/lib shows:
> 1100960 Feb 19 01:32 libdf.a
> 227036 Feb 19 01:32 libmfhdf.a
But config.log has a section:
> Undefined first referenced
> symbol in file > xdr_enum /usr/local/hdf4/lib/libmfhdf.a(var.o) (symbol belongs to implicit dependency /usr/lib/libnsl.so.1)
> With similar errors for xdr_float, xdr_int, xdr_u_long, xdr_double, xdr_long and xdr_opaque
I get the same problem with gdal 1.2.3 and gdal 1.2.6 and with either
my own compiled hdf4 or with a pre-compiled binary hdf4.
I have checked libnsl.so.1 using elfdump and it does not contain symbols which conflict
with those in the error message.
When I compile hdf4.2r1 and run gmake check, it passes most tests and
then crashes, repoorting:
> gmake[3]: Leaving directory `/disk0/add/gis/hdf4/HDF4.2r1/mfhdf/libsrc'
> HDF-SD C interfaces tests > ============================
> srcdir="." ./hdftest > hdfout.new
> gmake[2]: *** [check] Error 1 > gmake[2]: Leaving directory `/disk0/add/gis/hdf4/HDF4.2r1/mfhdf/libsrc'
> gmake[1]: *** [check-recursive] Error 1
> gmake[1]: Leaving directory `/disk0/add/gis/hdf4/HDF4.2r1/mfhdf'
> gmake: *** [check-recursive] Error 1
my hdf4 libs are in /usr/local/hdf4/lib. Includes in /usr/local/hdf4/include
and I run configure with:
> ./configure --with-szlib=/usr/local/lib --prefix=/usr/local/hdf4
I cannot understand what is going wrong here and would appreciate any help.
Thanks
Kingsley Burlinson Darwin
