[GRASSLIST:6591] "Grid" of points?
Is there any way to produce a set of evenly spaced vector points in GRASS?
--j
Jonathan A. Greenberg, PhD
NRC Research Associate
NASA Ames Research Center
MS 242-4
Moffett Field, CA 94035-1000
650-604-5896
AIM: jgrn307
MSN: jgrn307@hotmail.com
On Thu, 21 Apr 2005 13:40:25 -0700
--j
v.mkgrid will generate a grid with centroids and boundaries.
you could extract out the centroids or corners using v.extract
Perhaps others know an easier way.
T
Trevor Wiens
twiens@interbaun.com
The significant problems that we face cannot be solved at the same
level of thinking we were at when we created them.
(Albert Einstein)
> GRASS?
> --j
T
there is a way to convert vector lines into points at a regular interval.. it
is called v.to.points
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
Jonathan:
> GRASS?
Trevor:
Dylan:
interval.. it is called v.to.points
another trick is to set the region at the target size and ns,ew
resolution with g.region, then make a raster map with "r.mapcalc one=1"
and then use 'r.to.vect feature=point' to convert each raster cell to a
vector point, leaving you with a grid of points.
Hamish
