[GRASSLIST:6865] Lat long; illegal latitude
Hello,
this issue was already discussed a few weeks ago
(http://grass.itc.it/pipermail/grass5/2005-April/017946.html), however I do
not understand what the best work around is. Which file do I have to modify
or should it work with the most recent cvs version?
lat long location (EPSG 4326-- set up with GRASS 6 not 6.1):
Import of Lambert Azimuthal Equal-area img file (as well as UTM Wgs84 files)
failed
r.in.gdal input=/mnt/hdg1/ndvi_mask.img output=test -o -e
Over-riding projection check.
Proceeding with import...
WARNING: G_set_window(): Illegal latitude for North
Using GRASS 6.1 cvs minutes ago.
thanks in advance Martin
Martin Wegmann
DLR - German Aerospace Center
German Remote Sensing Data Center
Dept.of Geography
Remote Sensing and Biodiversity Unit
University of Wuerzburg
Am Hubland
97074 Würzburg
phone: +49-(0)931 - 888 4797
fax: +49-(0)931 - 888 4961
http://www.biota-africa.org
http://www.biogis.de
On Tue, May 24, 2005 at 12:05:52PM +0200, Martin Wegmann wrote:
Hello,
Unfortunately the problem is still open (I ran into it recently again
with global MODIS data). The only way I found so far (without hacking
GRASS) was to make the map smaller with gdal_translate. Of course
not the preferred way...
failed
Please post the coordinates section of
gdalinfo /mnt/hdg1/ndvi_mask.img
hi everybody,
Im trying to rectify some ortho-photos using the command i.ortho.photo, but i dont know where to find the coordinate to use with the photo.2image command. i dont have a camera reference file and i dont know where to find it. Any suggestion? is there a standard set of parameters i can try to use? The only parameter i know is the focus lenght (153.26mm) that can be readed directly from the photo. On the photo i can also read: "UAiG 6025 153.26", but i dont know what does it mean, (maybe the camere ID? where can i find parameters for this camera?).
Thanks for the help....
Luca p.
Email.it, the professional e-mail, gratis per te: http://www.email.it/f
  Sponsor:
Personalizza il tuo cellulare con un semplice sms, clicca qui
* Clicca qui: http://adv.email.it/cgi-bin/foclick.cgi?mid=3115&d=25-5
I made the map smaller, but the problem remains. How small does it have to be?
gdalinfo /mnt/hdg1/africa_mask.img
Driver: HFA/Erdas Imagine Images (.img)
Size is 3308, 2303
Coordinate System is:
PROJCS["Lambert Azimuthal Equal-area",
    GEOGCS["Sphere of Radius 6370997m",
        DATUM["Sphere of Radius 6370997m",
            SPHEROID["Sphere of Radius 6370997m",6370997,0],
            TOWGS84[0,0,0,0,0,0,0]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    PROJECTION["Lambert_Azimuthal_Equal_Area"],
    PARAMETER["latitude_of_center",0],
    PARAMETER["longitude_of_center",20],
    PARAMETER["false_easting",0],
    PARAMETER["false_northing",0],
    UNIT["meters",1]]
Origin = (-3995068.181818,1875795.454545)
Pixel Size = (1000.00000000,-1000.00000000)
Corner Coordinates:
Upper Left (-3995068.182, 1875795.455) ( 17d44'19.50"W, 16d 2'0.95"N)
Lower Left (-3995068.182, -427204.545) ( 16d36'16.52"W, 3d38'54.28"S)
Upper Right ( -687068.182, 1875795.455) ( 13d36'30.94"E, 16d54'18.15"N)
Lower Right ( -687068.182, -427204.545) ( 13d48'27.40"E, 3d50'13.41"S)
Center (-2341068.182, 724295.455) ( 1d16'34.00"W, 6d24'19.75"N)
Band 1 Block=64x64 Type=Byte, ColorInterp=Palette
  Min=0.000 Max=1.000
  Overviews: 827x576, 414x288, 207x144, 104x72, 52x36
Metadata:
  STATISTICS_MINIMUM=0
  STATISTICS_MAXIMUM=1
  STATISTICS_MEAN=0.57226930752748
  STATISTICS_MEDIAN=1
  STATISTICS_MODE=1
  STATISTICS_STDDEV=0.49474961275331
  STATISTICS_HISTONUMBINS=2
  STATISTICS_HISTOMIN=0
  STATISTICS_HISTOMAX=1
  LAYER_TYPE=thematic
  STATISTICS_HISTOBINVALUES=3258591|4359733|
  Color Table (RGB with 2 entries)
    0: 255,255,255,255
    1: 210,210,210,0
