I am new to using GIS and would like some help with GRASS 6.0.
I am trying to digitise old streetmaps into vector format. The scanned
images are in TIFF/PNG format and I want to draw vector graphics from
them. Any hint of the best way of doing this? Is there any online
documentation/tutorials you could point me to?
Thanks & regards,
dooshiant
___________________________________________________________
Yahoo! Messenger - NEW crystal clear PC to PC calling worldwide with voicemail http://uk.messenger.yahoo.com
On Tue, Jun 07, 2005 at 09:14:30AM +0100, dooshiant wrote:
Thanks & regards,
dooshiant
Am Dienstag, 7. Juni 2005 10:14 schrieb dooshiant:
we just finished the translation of our GRASS 6.0 documentation from german
into english. It also includes some hints on digitizing and geocooding
scanned maps - the HTML version can already be found here:
Is there the avalability of a pdf or an offline html version also planned? For
those of us who do not have instant access of the internet from our computers.
Miha Staut
> Hi all,
> Thanks & regards,
> dooshiant
How much free photo storage do you get? Store your holiday
snaps for FREE with Yahoo! Photos http://uk.photos.yahoo.com
Am Dienstag, 7. Juni 2005 14:26 schrieb Miha Staut:
> Hi,
> german into english. It also includes some hints on digitizing and
> geocooding scanned maps - the HTML version can already be found here:
> http://www.gdf-hannover.de/lit_html/grass60_v1.1_en/
> best,
> Otto
For those of us who do not have instant access of the internet from our
computers.
hi,
it is released unter GNU FDL. As for the german version, we will provide it
within the next days as:
HTML -> for online reading
LATEX Sources -> to convert into PDF, PS, ...
Printed book -> for home at cost price
I would like to query more than 150 raster layers with r.what, to extract the time evolution of a variable in a certan point of a map (each layer is for a different time step) but i do receive the error:
Giacomo Bertoldi, Ph.D.
Dept. of Civil and Environmental Engineering
University of Trento - ITALY
E-MAIL: giacomo.bertoldi@ing.unitn.it
Not sure if it's the best way but maybe a bash script will do the trick
for i in <list of raster maps>
do r.what input=$i east_north=$myeast, $mynorth >> temp
done
This will (hopefully) append the value to the temp file. Just not
entirely sure if the redirect (>>) should be inside the loop or after
the done statement. Can't test it right now
Daniel
g.region rast=geotiff_map
v.digit -n map=newmap bgcmd="d.rast geotiff_map"
- add any needed attribute columns in setup menu
- go!
> error:
> r.what: can only do up to 150 cell files, sorry.
> The call is:
> r.what input=$RASTERMAPS east_north=$myeast, $mynorth
> where $RASTERMAPS is the list of my files.
> How can I overcome this problem?
trick
done
or do less than 150 raster maps at a time and cat the resulting pieces
together...
grass6/raster/r.patch/nfiles.h says:
/* The number of cell files that can be patched together.
* All cell files will be opened at one time, so this number can not
* be arbitrarily large.
* Must be smaller than MAXFILES as defined in lib/gis/G.h which
* in turn must be smaller than the operating system's limit.
* (Given by `cat /proc/sys/fs/file-max` in Linux 2.4)
(same issue for r.series, r.patch, r.what, ...)
The first line of grass6/raster/r.what/main.c is: #define NFILES 150
You can make that (a bit less than) MAXFILES in lib/gis/G.h
(currently 256) without too much worry.
Beyond that you'll need to change MAXFILES too. Probably 1024 files
is ok, my system says 200k is file-max. But depends on your system.
Maybe I'll clean these up to reference G.h. The number can't be
'arbitrarily large' due to resource constraints. Search the mailing
lists for emails from Glynn on the subject for a better explanation.
Tried to import the raster file using r.in.gdal without success.
Can anyone advise how to get past the ¨WARNING: G_set_window(): Illegal
latitude for South¨ error I keep getting. Am I doing something wrong? I
did come across several references to this error message in the list
archives but could not find the solution.
