[GRASSLIST:7047] r.to.pg
hello
*Where can I find r**.**to**.**pg script to download from ?
regards
* <http://www.grass-gis.de/dassau/r_cross_pg/r.cross.to.pg.html&gt;
Ahmet Temiz
______________________________________
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster@deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
Am Dienstag, 7. Juni 2005 12:33 schrieb orkun:
hello
Maybe someone using GRASS 5.3 or 5.4 can provide it.
regards
-> now available again...
       Otto
hello
regards
      Otto
thank you
I think in grass6 raster to vector does what r.to.pg does internally.
as:
Column | Type | Modifiers
cat | integer |
value | integer |
label | character varying(95) |
Am Dienstag, 7. Juni 2005 14:13 schrieb orkun:
>>hello
>>regards
> Otto
thank you
right! you can convert the raster map into vector format and write all
attributes into PostgreSQL. But there is a difference: r.to.pg writes each
pixel value to the table, r.to.vect writes feature (points, lines, polygones)
attributes.
I guess, it depends on what you want to do. Some years ago, I needed raster
pixel values to be able to calculate statistics with R from PostgreSQL table
entries -> that's why r.to.pg was necessary and useful to me.
best wishes
   Otto
