Hi all;
I'm getting beautiful maps to be used in a presentation. And I'm usin "black"
as background color. So, when I want to display a map (this is a coastal
area) I use:
d.rast -o rastermap
In this way, null values are not displayed, and all cells belonging to sea
area black as the background.
The problem is when I use d.his, because this command doesn't allow to use a
color for nulls or to use -o to do nothing with nulls.
So, my question is:
Is it possible to get a new map with the output of d.his?
Or
Do you have any idea about how get a whole black background (including nulls)
with d.his?
Best regards
Javier
So, my question is:
Yes, with r.his.
Or
with d.his?
If you have the source, the attached patch makes "d.his -n" behave
like "d.rast -o".
(attachments)
d.his-patch (396 Bytes)
Hello javier,
So, my question is:
I wrote a module, which does this.
But be aware, that the resulting Map is only for diplaying-purpose,
because the colors are reduced, so further anaysis on this maps be
generalized and maybe wrong...
Basicly this script mainly combines r.his and r.composite in one
command.
Information about this is shown here:
http://mitglied.lycos.de/stephanholl76/d.his.save.html
download here:
http://mitglied.lycos.de/stephanholl76/d.his.save.tgz
hth
Stephan Holl
Stephan Holl
GnuPG Key-ID: 11946A09
19:51:20 up 3:57, 1 user, load average: 0.06, 0.09, 0.11
