I have these ASTER images, in hdf format. I tried to import then with
r.in.gdal, but I get errors:
r.in.gdal input=/home/guano/grassdata/AST_L1B_003_07042001134227_11162003075003.hdf
output=teste
ERROR 4: `/home/guano/grassdata/AST_L1B_003_07042001134227_11162003075003.hdf'
not recognised as a supported file format.
How can I get then into GRASS?
tks
Carlos Henrique Grohmann - Guano
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
I still cant have my ASTER imagens on GRASS. I have builted HDF4,
rebuilted GDAL with support for HDF4 and GRASS.
If I try r.in.gdal:
r.in.gdal input=/home/guano/grassdata/AST.L1B.00309052003132740.09242003132138.hdf
output=test band=1 -o -e
ERROR 4: `/home/guano/grassdata/AST.L1B.00309052003132740.09242003132138.hdf'
If I try r.in.aster:
r.in.aster input=/home/guano/grassdata/AST.L1B.00309052003132740.09242003132138.hdf
proctype=L1B band=1 output=test
georeferencing aster image
gdalwarp -t_srs +proj=lcc +lat_0=-18.0000000000 +lat_1=-8.0000000000
+lat_2=-28.0000000000 +lon_0=-46.0000000000 +x_0=2000000000.0000000000
+y_0=5000000000.0000000000 +a=6378160 +rf=298.25 +no_defs
+towgs84=-60.0,-2.0,-41.0
HDF4_SDS:ASTER_L1B:"/home/guano/grassdata/AST.L1B.00309052003132740.09242003132138.hdf":2
/home/guano/grassdata/amsul_lambert/sad69/.tmp/Valhalla/26909.0.tif
A target coordinate system was specified, but there is no source coordinate
system. Consider using -s_srs option to provide a source coordinate system.
Operation terminated.
importing into GRASS
ERROR 4: `/home/guano/grassdata/amsul_lambert/sad69/.tmp/Valhalla/26909.0.tif'
does not exist in the file system,
and is not recognised as a supported dataset name.
Carlos
Carlos,
if you want to use r.in.gdal, you will have to use the full reference to
a HDF4 subdataset as required by gdal as
HDF4_SDS:subdataset_type:file_name:subdataset_index. You can see that
r.in.aster does so, if you look at its output: it calls gdalwarp with
'HDF4_SDS:ASTER_L1B:"/home/guano/grassdata/AST.L1B.00309052003132740.09242003132138.hdf":2' as input file. You'll have to use something like that too. You can find out how to reference your hdf subdatasets by running gdalinfo on your hdf file (then indeed just give it the filename). It will tell you the full hdf reference and its subdatasets. For more info, see http://www.remotesensing.org/gdal/frmt_hdf4.html.
Vincent.
If I try r.in.gdal:
Carlos
Try the r.in.aster script. This uses gdalwarp to import and georectify the
aster imagery.
Michael
On 7/5/05 1:54 PM, "Carlos Guâno Grohmann" <carlos.grohmann@gmail.com>
r.in.gdal
output=teste
tks
____________________
C. Michael Barton, Professor of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
I tried r.in.aster:
proctype=L1B band=1 output=teste
/home/guano/grassdata/amsul_lambert/sad69/.tmp/valhalla/27109.0.tif
ERROR 4: `/home/guano/grassdata/amsul_lambert/sad69/.tmp/valhalla/27109.0.tif'
Something is worong with the coordinate system, which is not set in the image.
This is the first lines of gdalinfo:
Driver: HDF4/Hierarchical Data Format Release 4
Size is 512, 512
Coordinate System is `'
Metadata:
HDFEOSVersion=HDFEOS_V2.6
IDOFASTERGDSDATAGRANULE=ASTL1B 0309051327400309240184
tks Carlos
coordinate system. Consider using -s_srs option to provide a source
coordinate system. Operation terminated.
Carlos,
Your version of GDAL is outdated. Please, grab the most recent version
(you need the CVS snapshot). Everyone who need georeferenced ASTER
should take the GDAL sources from CVS, older code does not work
properly with ASTERs.
Best regards,
Andrey
Andrey V. Kiselev
Home phone: +7 812 5970603 ICQ# 26871517
