Dear GRASSusers,
it's seems that the subdivision of the monitor in two parts when running
d.rast.leg is a permanent feature. Every subsequent map display is performed
(randomly) in one of the two monitor parts. d.erase doesn't cancel the
entire monitor.
Is it necessary some other operation to clear the monitor or is this a bug
in my version (6.1 CVS)?
Many thanks
Aldo Clerici
Aldo Clerici wrote:
Dear GRASSusers,
entire monitor.
Just a guess:
d.frame -e
Does that work?
I always used to use that command for erasing monitors before I discovered d.erase. In fact as far as I understand it d.erase is not even necessary except to save typing?
Paul
> running d.rast.leg is a permanent feature. Every subsequent map
> display is performed (randomly) in one of the two monitor parts.
> d.erase doesn't cancel the entire monitor.Just a guess:
d.frame -e
Does that work?
It should. Also Markus just added 'd.erase -f' to remove all frames as
well.
Well d.rast without -o will clear the display command list (view with
d.save) anyway, saving the step.
Hamish
On Wed, Jul 13, 2005 at 05:33:45PM +0100, Paul Kelly wrote:
Aldo Clerici wrote:
>Dear GRASSusers,
>performed
Dear Aldo,
it's not randomly, but done on the left side (the last activated
frame). But, if the user resizes the screen, it switches to the
right side which apparently becomes the last frame after resize-redraw.
>entire monitor.
In 6.1 there is now
d.erase -f
to erase all frames. Without -f the active frame will be erased.
Just a guess:
d.frame -e
Does that work?
Yes, that's the (classical) alternative.
