Markus,
I believe this is the output from r.in.gdal in the window at the bootom of the GUI screen.
Running 6.1 CVS (bleeding edge of course), although I also received simmilar errors on 6.0
linux-2.6.11-gentoo-r5
i think the error is because I was importing a raster of one projection into a location of another projection. Unless this does not look like the std error output. Let me know if you need me to repeat it. I will be scrapping the dataset soon to start over but I'll hold on until I hear from you.
My location as seen by GRASS
LOCATION PROJ_INFO is:
GRASS_INFO_ERROR(10270,2): name: Lat/Lon
GRASS_INFO_ERROR(10270,2): proj: ll
GRASS_INFO_ERROR(10270,2): datum: wgs84
GRASS_INFO_ERROR(10270,2): a: 6378137
GRASS_INFO_ERROR(10270,2): es: 0.0066943800
GRASS_INFO_ERROR(10270,2): no_defs: defined
how did you manage to generate these fancy GRASS_INFO_ERROR
messages? Which version/platform? Looks like a bug to me...
|Dave Sampson: Geographic Information System (GIS) Technician |
|Centre for Sustainable Watersheds |
|Cooperative Approaches to Protect Canada's Water Resources |
|14 Water St, P.O Box 280. Portland Ontario, Canada. K0G 1V0 |
|Lat: 44.700 Long: -76.19 |
|www.watersheds.ca gis@watersheds.ca |
