[GRASSLIST:797] r.statistics
Dear list,
when I use r.statistiucs in GRASS-5.0.2 I get the following error
message:
"ERROR: This module currently only works for integer (CELL) maps"
I am using a category map as base map and a floating point map as cover.
This error does not appear when I use r.average with the same raster
maps.
Is there a bug in r.statistics? Or do I still have to assign category
values to one of the maps?
Ulrich
Ulrich Leopold MSc.
Dep. Phys. Geography and Soil Science
Inst. for Biodiversity and Ecosystem Dynamics
Faculty of Science
University of Amsterdam
Nieuwe Achtergracht 166
NL-1018 WV Amsterdam
Phone: +31-(0)20-525-7456 (7451 Sectretary)
Fax: +31-(0)20-525-7431
Email: uleopold@science.uva.nl
http://www.frw.uva.nl/soil/Welcome.html
message:
maps.
It's a limitation.
Or do I still have to assign category values to one of the maps?
The simplest solution is to quantise the cover map with r.mapcalc,
e.g.
  r.mapcalc 'foo.quant = int(foo * 1000)'
Choose a scale factor which is large enough to give a reasonable
resolution. However, larger scale factors will result in increased
memory usage and slower execution, particularly for larger maps.
