[GRASSLIST:799] Automatic creation of Areas (polygons) from connected lines
Hello,
I suspect the question has already been asked, but I didn't
find an obvious answer.
Given a vector file with a correct topology (all lines are
connected and broken at nodes) is there a "magic" modules
allowing the creation of areas (parcels) from this vector
file? [to go the raster way is not an option here due to the
precision and hence the size of the resulting file]
Thanks for the help!
tlaronde@polynum.org said:
Hello,
Could you please be a bit more specific:
- in what format is you correct vector file ?
- does this file contain lines and you want to transform them into areas ?
- If your file is in GRASS format and contains lines that you wish to
transform into areas, you can try v.line2area.
Moritz
En réponse à Moritz Lennert <mlennert@club.worldonline.be>:
> Hello,
Thanks for the reply. Eventually I already found the answer in a message :
(this is GRASS vector format)
v.line2area
v.alabel
do the job perfectly.
BTW, I suggest for newcomers like me to emplasize in the doc the fact that
GRASS is a topology engine able to build aread from edges : no need to import
CAD shapes and so on (that has mistaken me at the begining).
