[GRASSLIST:8] d.rgb still crashes...
I've just installed the cygwin grass5.0.2 from the download site and tried
to display a composite image using d.rgb and the display window still
crashes when I try to run the command. Since I've never tried to fix someone
else's GRASS code, how should I go about getting this fixed?
Jeff.
My original fix was incorrect; I have an updated fix (patch attached,
against 5.0.2, but that doesn't help if you don't have the source
code).
I've CC'd this to the wingrass list in the hope that someone is
willing to provide an updated libG11.dll binary.
(attachments)
xlib.c.diff (873 Bytes)
