[GRASSLIST:8192] Re: Grass6.0.1 Binaries for Mandrake 10.0
Am Dienstag, 6. September 2005 23:33 schrieb Alejandro Hinojosa:
Dear list,
Dear Alejandro,
Since nobody came to the rescue but Otto , let me tell you how i fixed
using the binary distribution intended for Mandrake 10.1 in version 10.0
This is to solve the dependencies of the distribution rpms. Otto indirectly
suggested to migrate to 10.1, but sometimes it's to much hassle to
backup everything before migrating.
Do you remember, what packages you had to upgrade on your mandrake 10.0. I
could add your information to the readme - for other users.
I followed the installation sequence defined in the readme of the
distribution site for Mandrake
http://www.gdf-hannover.de/media.php?id=1&lg=en
then when the dependencies started to appear i went
to http://rpm.pbone.net and searched for the libraries requested,
download them and installed manually with root privileges with rpm
-ivh package.rpm.
At the end, I got grass60 to run. I hope I don't get into furture problems
for running on version 10.0.
My first surprise, besides the interface, is that it will not see my old
vectors from 5.4.
thanks for your comments!
   Otto
Alejandro
  At 11:22 PM 9/5/2005 +0200, you wrote:
>On Mon, 5 Sep 2005, Alejandro Hinojosa wrote:
>>Dear list,
>Dear Alejandro,
>>I have Mandrake 10.0 running on my pc box and downloaded the rpm binaries
>>for grass 6.0.1 from gdf-hannover.
>>Will this version run under Mandrake 10.0?
>>I started following the installation order from the readme,
>>doing manually with rpm -i -v package.rpm . The first package
>>(proj-4) installed without trouble, but didn't know where it was
>>installed. For the second package (gdal-1.3.0-2mdk10.1.i586.rpm) the
>>installation aborted with errors:
>>Failed dependecies
>>libstdc++.so.6 is needed by gdal-1.3.02mdk10.1
>>under /usr/lib there is a libstdc++.so.5 but no libstdc++.so.6,
>>Any clues, directions? Do I need the Mandake 10.1 or a symbolic link
>>from libstdc++.so.6 to libstdc++.so.5 will do.
>you can try a symbolic link, but I don't think this will work. The
>packages are compiled on a mandrake 10.1 and unfortunately not build for
>Mandake 10.0 - sorry.
> otto
>>Thanks
>>Alejandro Hinojosa
>>Geology Department ,Earth Sciences Division
>>CICESE
>>Ensenada, Baja California, Mexico
>>Alejandro Hinojosa
  Answering Otto an Michelle,
I didn't force any of the package installation with the -f switch, actually there were only two fixes. The dependencies that had to be resolved are
gdal-1.3.0-2mdk10.1.i586.rpm asked for libstdc++.so.6
and
grass-6.0.1-2mdk10.1.i586.rpm asked for libfftw.so.2
and regarding Michelle's comment that this is not a grass issue, unfortunately to get grass running you need to know something about make, rpm (or equivalent),shell scripts, root privilegdes and package installation, at least it helped me get it running. I hope I didn't mess something else.
Alejandro
> Dear list,
Dear Alejandro,
> -ivh package.rpm.
> vectors from 5.4.
   Otto
> Alejandro
> >>Dear list,
> >Dear Alejandro,
> >>Failed dependecies
> > otto
> >>Thanks
> >>Alejandro Hinojosa
> >>CICESE
> >>Alejandro Hinojosa
Hi Alejandro,
and
you are right - the fftw dependency can easily be resolved with the original mandrake 10.0 rpm libfftw2-2.1.5, but for libstdc++.so.6, what package or procedure resolved the libstdc++.so.6 dependency? Or did you
compile sources?
Was it possible to simply install the libstdc++6-3.4.0-0.4mdk.i586.rpm from mandrake > 10.0. Maybe you could describe what you did with the necessary commands. That might help other people using Mandrake 10.0.
thanks a lot!
  Otto
Alejandro
> Dear list,
Dear Alejandro,
> -ivh package.rpm.
> vectors from 5.4.
   Otto
> Alejandro
> >>Dear list,
> >Dear Alejandro,
> >>Failed dependecies
> > otto
> >>Thanks
> >>Alejandro Hinojosa
> >>CICESE
> >>Alejandro Hinojosa
