[GRASSLIST:8201] MrSID and incorporating the .sdw info into resulting GeoTiff.
I have a bunch of .sid files that I am converting to GeoTiffs. How
does one incorporate the spatial location information in their
associated .sdw file into the associate .tiff file?
Here's what I am doing:
mrsiddecode -i FILE.sid -o FILE.tif -of tifg
## Use the code for NAD27, Zone 12
## contained in EPSG file: /usr/share/proj/epsg
gdal_translate -of GTIFF -a_srs '+init=epsg:26712' \
  FILE.tif FILE.NAD27.tif
But when I do a gdalinfo, it is clear that the information in the .sdw
file has not been used (the "file.sdw" is given below):
gdalinfo file.tif
Driver: GTiff/GeoTIFF
Size is 9168, 9168
Coordinate System is:
PROJCS["NAD27 / UTM zone 12N",
    GEOGCS["NAD27",
        DATUM["North_American_Datum_1927",
            SPHEROID["Clarke 1866",6378206.4,294.9786982138982,
                AUTHORITY["EPSG","7008"]],
            AUTHORITY["EPSG","6267"]],
        PRIMEM["Greenwich",0],
        UNIT["degree (supplier to define
representation)",0.01745329251994328],
        AUTHORITY["EPSG","4267"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",-111],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","26712"]]
Origin = (-0.500000,9167.500000)
Pixel Size = (1.00000000,-1.00000000)
Corner Coordinates:
Upper Left ( -0.500, 9167.500) (115d29'19.33"W, 0d 4'57.69"N)
Lower Left ( -0.5000000, -0.5000000) (115d29'19.32"W, 0d 0'0.02"S)
Upper Right ( 9167.500, 9167.500) (115d24'23.63"W, 0d 4'57.72"N)
Lower Right ( 9167.500, -0.500) (115d24'23.61"W, 0d 0'0.02"S)
Center ( 4583.500, 4583.500) (115d26'51.47"W, 0d 2'28.84"N)
The associated .sdw file is:
             1.200000000000000
             0.000000000000000
             0.000000000000000
            -1.200000000000000
        492501.000000000000000
       6243621.000000000000000
gdalinfo file.tif
Size is 9168, 9168
    GEOGCS["NAD27",
    UNIT["metre",1,
Corner Coordinates:
             1.200000000000000
             0.000000000000000
             0.000000000000000
            -1.200000000000000
Try renaming the .sdw file to .tfw
Also try gdalinfo on the file.tif to be sure that the original reference system
is "seen".
Richard Greenwood
richard.greenwood@gmail.com
www.greenwoodmap.com
On Wed, Sep 07, 2005 at 05:46:00PM -0600, we recorded a bogon-computron collision of the <caumann@ualberta.ca> flavor, containing:
Rename (or copy) the .sdw file to have the same name as the .tif you created,
but with a .tfw suffix. gdal_translate will know that it's the world file
associated with your tif and use it.
I.e.
cp FILE.sdw FILE.tfw
Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1
"The only thing you can do easily is be wrong, and that's hardly
  worth the effort." -- Norton Juster
Even easier - use the -wf option in mrsiddecode:
mrsiddecode -i FILE.sid -o FILE.tif -wf -of tifg
And if the mrsiddecode geotif output is broken like this, why use geotif at all at this step? Just drop the '-of tifg' option and let gdal_translate create the geotif.
I.e.
William Kyngesburye <kyngchaos@kyngchaos.com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
Thanks for everyone's responses here! It turns out that:
mrsiddecode -wf -input FILE.sid -output FILE.tif
gdal_translate -of GTIFF -a_srs '+init=epsg:26712' FILE.tif
FILE.NAD27.tif
does the right thing, but simply changing the first line to:
mrsiddecode -of tifg -input FILE.sid -output FILE.tif
causes the translation to fail (i.e., not read the .tfw file).
I have no idea why this is the case. In the first case, given that
mrsiddecode generates a tfw file, is the resulting FILE.tif now storing
a link to this file that it lacks in the second case (using -of tifg)?
I'm running:
mrsiddecode -v
mrsiddecode: mrsid decoder tool
Version 4.0.10.720.Bob_713_br
Built Oct 12 2004 16:28:22 (linux, gcc3, release)
Gdal_translate:
GDAL 1.2.1.0, released 2004/06/23
Thanks again for you help!
Craig
You don't need the 'cp FILE.sdw FILE.tfw' step - that's what the -wf mrsid option does.
Also, what about using the v5 mrsid DSDK release? Maybe the geotif bug is fixed there.
FILE.NAD27.tif
I'm running:
mrsiddecode -v
Gdal_translate:
Craig
"Oh, look, I seem to have fallen down a deep, dark hole. Now what does that remind me of? Ah, yes - life."
- Marvin
