[GRASSLIST:8472] converting raster value of 0 (black) to null
I have a radar map that has a 0 value for black. This came from a
grayscale GeoTIFF.
I need to convert the 0 value to null so that I can overlay it onto a
base map.
I have tried using mapcalc with the following:
radarnew=if(radar=0,null(),radar)
but this produces a magenta raster map with no other data in it.
r.mapcalc is very new to me and I cannot seem to make heads of tails of
how to do this from reading the man page. Any pointers would be great.
Ed Davison
Ed, you can try this. First, I think you need to put quotes around your if statement. The command line is probably choking on the parentheses. So instead of
try
r.mapcalc radarnew = 'if(radar=0, null(),radar)'
Or you could just use r.null (designed specifically for your purpose).
-Ian
grayscale GeoTIFF.
base map.
Ed Davison
What happens if a big asteroid hits Earth? Judging from realistic simulations involving a sledge hammer and a common laboratory frog, we can assume it will be pretty bad.
  - Dave Barry
This message has been scanned by Postini anti-virus software.
Do you have 2 equal signs in your logic statment?
David
grayscale GeoTIFF.
base map.
Ed Davison
David Finlayson
Marine Geology & Geophysics
School of Oceanography
Box 357940
University of Washington
Seattle, WA 98195-7940
USA
Office: Marine Sciences Building, Room 112
Phone: (206) 616-9407
Web: http://students.washington.edu/dfinlays
try
That did the trick exactly. I had no idea this one existed and it
worked perfectly.
Per another post, I also determined that the radar=0 should have been
radar==0 which is why I got the all pink result.
Thanks to all for the pointers.
Ed Davison
