Hello!
I want to ask something about module i.points
First I mark one point on map, and then I have to insert real coordinate for that point.
I want to ask can coordinate be in Latitude-Longitude or is MUST be in UTM???
Coordinate system on target LOCATION is set to Latitude-Longitude system.
Thanks!
Josip Vrlic
Josip, I think that you are supposed to enter coordinates as whatever your target location is. So if you are projecting into a latlong, use degrees. Be careful with dd:mm:ss.sss vs. dd.ddddd. I think you might need to append the directional modifier as well (N,E,S,W) for the dd:mm:ss case. For example 30:28:55.45N.
Hope this helps,
Ian
On Oct 12, 2005, at 4:16 AM, Josip Vrlić wrote:
Hello!
Thanks!
Josip Vrlic
This message has been scanned by Postini anti-virus software.
