Is there a module that will create rasters from this data format, or,
alternatively, is there a handy way of massaging this data into
Grass-friendly format?
~ Eric.
Eric Patton
Technologist, Geo-Spatial Data Services
Geological Survey of Canada (Atlantic)
Natural Resources Canada
Bedford Institute of Oceanography
Dartmouth, Nova Scotia, Canada B2Y 4A2
Postal address: P.O. Box 1006
Courier address: 1 Challenger Drive
~ Eric.
Eric Patton
Carlos Henrique Grohmann - Guano
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
~ Eric.
Eric Patton
If the xyz data is pre-gridded you can go the v.in.ascii + v.to.rast
route as others mentioned (or r.in.ascii); if it isn't you can use
v.surf.rst or v.surf.idw to make a surface. Alternatively you could do
v.to.rast and then r.surf.contour or r.surf.idw.
