[GRASSLIST:8829] Re: GRASS and xgrid
Jachym,
xgrid is a method for parallel processing, not a data format. The issue is that I'd like to run many (many) r.los (or r.cva on a large sample) - I've estimated what I need is in the region of a few months+ processing time. I've got xgrid running in my lab, but there are issues (a) with the grass shell and (b) the fact that the code for r.cva or r.los isn't parallel. I could break the job down into chunks and send it to xgrid to have it farmed out, but I'd like to know if anybody has already tried this.
Cheers, James
Trent University, Canada
hi,
on http://www.gdal.org/formats_list.html you can find data formats,
supported by GDAL library (and GRASS).
I'm affraid, xgrid is not between supported formats, try another one.
Jachym
Hello James
I feel a better long-term solution would be to re-write r.los/r.cva to use a more efficient algorithm. For a long time I've wanted to try and implement the algorithm described in
"A fast algorithm for approximate viewshed computation" by David Izraelevitz (U.S. Army Corps of Engineers) in Photogrammetric Engineering and Remote Sensing vol. 69 no. 7, July 2003 pp 767-774
but never had time and I don't really do any GRASS development work now so it won't happy any time soon. I think I've mentioned it before on the list but just thought it would be worthwhile mentioning it again.
Paul
