[GRASSLIST:9046] compiling GRASS with OpenGL
Dear all,
while compilinmg GRASS 6.0.1 on SuSE Linux 9.3 I get the following error:
CFLAGS="-O2" LDFLAGS="-s" ./configure
--prefix=/usr/local \
--bindir=/usr/local/bin \
--enable-shared \
--with-cxx \
--with-fftw=yes \
--with-gdal=/usr/local/bin/gdal-config \
--with-freetype \
--with-freetype-includes=/usr/include/freetype \
--with-postgres=yes \
--with-postgres-includes=/usr/include/pgsql \
--with-mysql=no \
--with-odbc=no \
--enable-largefile \
--with-opengl-libs=/usr/X11/lib
---------------snip-----------------------------
checking whether to use OpenGL... yes
checking for location of OpenGL includes...
checking for GL/gl.h... yes
checking for GL/glu.h... yes
checking for location of OpenGL library... /usr/X11/lib
checking for glBegin in -lGL... no
configure: error: *** Unable to locate OpenGL library.
Which OPenGL libraries are needed and where do they usually occur? I thought I
located them in /usr/X11/lib or /usr/lib but none of these directories work.
Cheers, Ulrich
There needs to be a file called libGL.so or libGL.a. libGL.so is
usually a symlink to e.g. libGL.so.1.2; the file to which the symlink
refers must exist.
If you can't see any obvious problems, check the config.log file for
any relevant error messages. It may be that one of the libraries which
libGL requires doesn't exist.
