[GRASSLIST:9368] grass launch error?
I upgraded to 6.0.1. I think this is the first time i fired it up since the upgrade.
any ideas?
GRASS 6.0.1 (hawaii):/data > Error in startup script: ps.map: error while loading shared libraries: libgdal.so.1: cannot open shared object file: No such file or directory
while executing
“exec ps.map -p”
(procedure “DmPrint::init” line 14)
invoked from within
“DmPrint::init”
(procedure “main” line 32)
invoked from within
“main $argc $argv”
(file “/usr/local/grass-6.0.1/etc/dm/d.m.tcl” line 894)
since the upgrade.
any ideas?
Either:
1. you don't have GDAL installed
or
2. the name of your GDAL library file is different that expected
libgdal.so.1
1. install GDAL
2. symlink your GDAL lib file libgdal.so.1
Read the archive, this is a common problem when installing Grass from
precompiled binary package.
Maciek
W polskim Internecie s± setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.epf.pl/
