[GRASSLIST:939]
I try to use s.vol.rst to interpolate some temperature values but i get some error message....
I know I have few points but i guess that's not the problem.....
I get CSV experimantal code and install the g3d components.
So my operation was:
1--> g3.createwind
2--> g3.region and get this region:
CURRENT REGION: N=170012.5 S= 73987.5 RES=200.05208333 ROWS=480
                 E=742512.5 W=672487.5 RES=200.07142857 COLS=350
                 T= 3500 B= 100 RES= 200 DEPTHS=17
PROJECTION: 99 (Swiss. Obl. Mercator)
ZONE: 0
3-->s.vol.rst input=temperatura@laura cellinp=ti25dem npmin=3 segmax=400 cellout=temp3d elev=temp3dvol
but i get this rensponse:
Percent complete: Error in COGRR!
ERROR: Interp_call failed!
Can be some NULL value in the cellinp raster file the problem?
Can be too few points the problem?
Have you any idea???
Has anybody else used with succes thi s.vol.rst command?
Thanks you all.
Eng. Massimiliano Cannata
Phd student
www.supsi.ch
Phd student
www.supsi.ch
