Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
It’s been 11 days, proposal accepted with 9 +1 and one missing vote, now assumed to be +0.
I’m going to merge the PR today. There is a build failure, but it looks like the usual (annoying) random maven lock one.
Hi Jody,
indeed I’ve noticed post merge that the OGC API features documentation didn’t get moved out
to services, but it’s still in community land.
Add any general background detail, such as configuration of freemarker templates, to Server configuration to avoid repeating the same content for each service.
