Final Report for Google Summer of Code 2024
Project description
I worked on the “istsos-miu”, which is part of the OSGeo Foundation for the Google Summer of Code 2024 project. The goal of the project was to add support for the generation of STAC metadata and the ability to search the data.
What I have done
For the duration of Google Summer of Code 2024, I contributed to implementing STAC metadata extraction within the istsos project as an independent module.
As the project started, with the support of mentors, I started to understand more about SensorThings API and its usage (although there is much more to learn). I started to work on allowing users to generate the STAC metadata JSONs by extracting data from the project URL.
STAC’s objective is to standardize how geospatial metadata is queried and structured. The STAC specification is an open specification developed to improve the discovery, accessibility, and interoperability of geospatial datasets. STAC provides a common, interoperable metadata framework to expose geospatial assets, like satellite images, either of optical or SAR, or other spatiotemporal data. STAC allows ease of access to different formats of spatial data through a common way to find more information about the geographic location over a period of time
Also as per stacspec.org : -
“STAC specification is a common language to describe geospatial information, so it can more easily be worked with, indexed, and discovered.”
The STAC metadata allows for finding spatial data over time for a given geographical location in a more standardized way.
To develop the metadata, I worked on parsing the responses for the generation of item, collection, and catalog JSONs, making the data querying and searching easier while adopting the common standards.
Extraction of metadata
I have implemented the stacfromsta module for the generation of metadata for a given STA project URL. We adopt the following mapping, as shown below:
The process flow of work is also shown:
The module generates the catalog, collection, and item JSONs, depending on the requests by the user to generate for all things or specific things.
Data querying and visualization
To query the data and visualise it, we use eoAPI with very minor modifications. It supports the searching of STAC metadata based on stac-fastapi, pgstac and visualisation using StacBrowser.
The current state of the project
The objective of the project was to add support for STAC(SpatioTemporal Asset Catalog) to istSOS-miu, and serve it to search and visualise the metadata that has been achieved.
Code Repository
The developed and merged code can be found here on the project repository -
https://github.com/istSOS/istSOS4-STAC
Pending work
The primary objective of the project is successfully completed, and the functionality to support it is implemented.
Potential Future Work
The generation of metadata is successfully done, although there is future scope for improvement to enable more efficient extraction of data and allow filtering-based specific data extraction.
More modifications can be done to the item data structure by integrating other fields or changing existing fields.
Conclusion
While working through Google Summer of Code 2024, I learned much about the Spatio Temporal Asset Catalog (STAC) and SensorThings API (STA). The project helped me to improve my skills in data processing, API development, and the importance of visualization, and I learned a lot more.
The most crucial learning being open-source collaboration and how impactful discussions can be to achieve more understanding and knowledge. It is great to be a part of GSOC 2024, and I am really happy to contribute to the project. It gave me a great experience of working on developing a project. The learning outcomes are highly impactful, and I would like to work more with the open-source community.
Acknowledgments
I want to extend my thanks to my mentors, Daniele, Massimiliano, and Claudio for their guidance and support throughout the Google Summer of Code 2024.
I am also grateful to the OSGeo Foundation for giving me the chance to work on this project and giving me a great experience.
Other useful links
- Project Proposal
- Project Repository
- Project Wiki
- istSOS-miu Wiki
- OSGeo GSoC 2024
- STAC and STA mapping
- Process workflow
- Images folder
Images
API collection example
Items in collection
Querying the API
Response of the API
Browser UI
Browser filter example
Browser filter result
Browser showing item and asset
Chetan
