- What I got done this week?
- Attended weekly meeting on Monday(May 27th 2024)
- Changed the name of the function from
pgr_bradesBetweennessCentralityto justpgr_centrality - Added some of the necessary files for implementing
pgr_centrality.-
doc/metrics/- CMakeLists.txt, metrics-family.rst, pgr_centrality.rst -
docqueries/metrics- CMakeLists.txt, doc-centrality.result, doc-centrality.test.sql, test.conf -
sql/metrics- CMakeLists.txt, _centrality.sql, centrality.sql -
src/metrics- CMakeLists.txt, centrality.c, centrality_driver.cpp
- Modified the files in the sql/ and src/ directories (licenses and function names)
- Added metrics to configuration.conf
- Studied BGL’s Brandes Algorithm for Betweenness Centrality and wrote a small code snippet for it on the sample data.(Link)
What I Plan on doing during June 3 - June 9, 2024?
- Finishing up the basic code skeleton by adding the relevant driver files and pgtap files.
- Start working on sample test cases for the documentation and on the documentation
Am I Blocked on anything?
- The job that I have right now has me working 12 hour shifts (can be night shifts later on) on a 20 days on and 10 days off split. So the hours that I put in might not be enough right now as I am getting used to the work culture and schedule. I will restructure the deliverables such that I do most of the work during those 10 days off and hit the mid term evaluation goals on time.
Luckily, I will have my holidays from June 15th and will be able to dedicate more time to cover up for the previous weeks.
