- What I got done this week?
- Attended weekly meeting on 3rd June 2024
- Worked on and added documenation in pgr_centrality.rst
- Studied the codebase to make docqueries work.
- Merged remote tracking branch pgrouting develop into centrality-week2
- Added remaining necessary file to make the code compile
- include/drivers/metrics/centrality_driver.h
- Adjusted centrality.c
- worked on documentation specifically on pgr_centrality.rst
- Start implementing pgr_centrality()
- This week I couldn’t work a lot due to frequent power cuts in Pune due to the heavy rainfall.
What I Plan on doing next week?
- Finishing up the basic code skeleton by adding the relevant driver files and pgtap files.
- Start working on sample test cases for the documentation and on the documentation
- Get the docqueries to work
- Fix the problems in the code from the first two pull requests
Am I Blocked on anything?
- The job that I have right now has me working 12 hour shifts (can be night shifts later on) on a 20 days on and 10 days off split. So the hours that I put in might not be enough right now as I am getting used to the work culture and schedule. All the time lost and work not done will be compensated in the following two weeks as I have days off from work starting from 13th June 2024 till 22nd June 2024.
