Progress Report for Week 11 (Aug 11 – Aug 17)
1. What did I get done this week?
- CI split into Unit & Integration jobs in zoo-cwl-runners:
- Unit job runs minimal tests under tests/unit with Python 3.10.
- Integration job added to fetch runner/common repos and run integration tests (with Calrissian temporarily skipped).
- Workflow trigger fixes:
- enabled push/PR on main and workflow_dispatch; ensured PYTHONPATH=$PWD for unit tests.
- Dependency alignment:
- standardized CI to Python 3.10 (matching prior Week 3 resolution).
- Packaging work (local deps checked out by CI under deps/):
- zoo-runner-common: added pyproject.toml (setuptools with py_modules), editable install now succeeds.
- zoo-template-common: Poetry build failed because zoo_template_common/ package dir is missing/empty; identified fix (create package folder and init.py, or switch to setuptools py_modules).
- Repo checkout corrections:
- Fixed integration job to use your forks (Aryankhare…) and corrected name mismatch for WES earlier (now using your fork).
- Known blockers captured by CI:
- Unit job: main_runner.py imports runners at import-time; causes ModuleNotFoundError without installed runners.
- Integration job: zoo-template-common packaging not yet recognized; Calrissian runner may still need special handling due to pycalrissian.
2. Plan for Next Week ( Aug 18 - Aug 24):
Finish packaging for zoo-template-common
- Create zoo_template_common/ folder, move common_execution_handler.py & common_stac_io.pyinside, add init.py, keep Poetry pyproject.toml.
- Re-run integration job to confirm editable install works.
Stabilize main_runner.py imports (unit job)
- Make runner imports lazy (inside a function) or guard with SKIP_RUNNER_IMPORTS=1 in unit job so import main_runner succeeds without runners installed.
Advance integration CI incrementally
- Keep Argo & WES integration tests running.
- For Calrissian: either pin a known-good pycalrissian or continue skipping with -k "not calrissian"until resolved.
Add CI badge & brief docs
- Once green, add GitHub Actions badge to README.md.
- Document the CI layout (unit vs integration, how deps are checked out/installed).
3. Am I blocked on anything?
- No, I am not currently blocked on anything.
4. Refrences:
[1] - GitHub - Aryankhare1225/zoo-runner-common: Common code for ZOO runners – includes ZooStub and BaseRunner
[2] - GitHub - Aryankhare1225/zoo-cwl-runners: Centralized repository for ZOO-Project CWL runners
