GSoC 2025 Week 5 Report: King Ordering Algorithm and Minimum Degree Ordering Algorithm
Week 5 Report (Jun 30 – Jul 6)
Reporting Week: Jun 30 – Jul 6
Status: :white_check_mark: On track
:white_check_mark: What I got done this week:
  • Replaced all usage of the custom II_t_rt data structure with standard int64_t types for result handling across the codebase.
  • Refactored ordering function interfaces to return std::vector<std::vector<int64_t>> instead of custom types.
  • Reduced SQL output columns from 3 to 2 and updated corresponding C function definitions.
  • Adjusted function signatures and removed legacy structures.
  • Cleaned up pgTap test files to reflect new function return structure.
:spiral_calendar: Plan for Week 6 (Jul 7 – Jul 13):
  • Implement kingOrdering and minDegreeOrdering functionality in ordering.hpp.
  • Add additional pgTap test cases
  • Continue improving test coverage for kingOrdering and minDegreeOrdering.
:construction: Am I blocked on anything?
No.
:link: Links
Thank you! :raising_hands:
