Anna Petrasova, Corey White, Vaclav Petras
My name is Salih Tangel, and I am a Master’s student currently working as a Research Assistant. I am writing to express my strong interest in the ‘JSON output for C modules’ project for the upcoming GSoC 2026 cycle.
I have already set up the GRASS development environment and have been analyzing the implementation of G_json in modules like g.region and g.list. I’ve noticed that the transition is well underway but not yet complete across the entire codebase.
Since I am proficient in C and familiar with the GIS ecosystem, I believe I can contribute significantly to standardizing these outputs. Could you please let me know if there is a ‘roadmap’ for the remaining modules, or if I should identify a set of modules to propose for this year’s cycle?
Thank you for your time and for all the work you do for the GRASS community.
Hi Salih,
Thank you for your interest! Sorry for the slow response, I am just now setting up the GRASS GSoC page with ideas - this page will still change as we update the topics.
Yes, we plan to open this topic again, but since most of the tools are already implemented, we are considering to expand this topic to include Python tools as well. I still need to identify the tools, on the C side we would e.g. like to rewrite v.db.select using parson library, v.build could have a json output and couple more. Among Python based tools, many temporal tools would benefit from json (e.g. t.list, t.rast.list…).
There will be other topics as well, so you can consider e.g. OpenMP parallelization.
For any of the topics we would like the prospective participants to open one or more PRs solving a bug or implementing something related to the project topic to verify the project is a good match. I hope to have some suggestions on test of skills listed for each topic as we update the ideas page. But you can always check open issues.
Best,
Anna
Hi Anna,
Following up on the JSON modernization goals, I have successfully set up the GRASS build environment on a macOS M4.
As a first step to test the workflow, I modified v.net (report.c) to include a JSON output option using the parson library (via gjson.h). I’ve verified that the new parameter is correctly integrated and recognized after a full build.
Now that , I am ready to tackle v.db.select as you suggested, or dive into the Python-based temporal tools like t.list.
(Note: I encountered some PDAL detection issues on M4, which I bypassed for now to focus on the JSON implementation.)
Sorry if I missed it, but did you submit a PR for the v.net changes? It would be good to add test and documentation for that.
Hi Yes, I have just submitted the Pull Request. I made sure to include both the automated tests and the documentation updates as you suggested.
Here is the link to the PR: https://github.com/OSGeo/grass/pull/6999
I’m a bit new to this workflow, so please let me know if everything looks correct or if I need to adjust anything. What would be the next steps after this, and is there anything else you need me to work on or improve? Thank you.
Also, just a quick note: I included some basic status tracking and error handling in the JSON output to make it more robust. If this makes the PR too large for a first contribution, I’m happy to simplify it. Just let me know what you prefer
Hi Anna, since I had an exam this week so I was busy studying. I’ve finally managed to complete the changes as requested and I’m happy to send this pull request. Thank you for your patience!
Hi GRASS team,
I am Gulshan Kumar, a 3rd year Bachelor in CS from India. My github id is @gulshan-123
I am interested in the GSoC project: Add JSON output to different tools. I am currently writing my proposal for the project.
I have noticed that there are some tools like v.delaunay, v.net.allpairs, v.net.bridges, and many more v.net``.*. In these tools there are no stdout, instead the results are written in new map. Although we can view the result in different formats using v.db.select <newly created map> format=<json/plain>. Should we add stdout with JSON and plain format for these tools too? This may be useful if user don’t want to create new maps and just want to analyse it. But one cons may be maintaining consistency among those modules and v.db.select output format.
Also, should I share my proposal link public to all or only to the mentors (In this case, please provide the mail ids to share with, as I could not find it in gsoc idea page.) I am writing my proposal in latex, so I will share the commentable pdf link once ready.
Thank You
cc @annakrat
Only with the mentors, I’ll send them separately. I usually prefer the proposal in a form I can comment on directly, e.g. google doc, overleaf etc.
Regarding the tools, some of these may benefit from a JSON output, but that would be case by case. We noted on the wiki, most ‘obvious’ tools are done, but we are confident there is still a lot to do.
One other thing to note is that it may be useful to submit a second proposal (check the GSoC rules about that) on a different topic, there are likely be multiple students applying for this one.
