GSoC 2026 Introduction by Soham Babrekar
Hello pgRouting Community,
I’m Soham, an engineering student with a strong passion for open-source development. With a solid foundation in C++ and a drive to grow as a developer, I’m eager to start contributing to pgRouting and be a part of this vibrant community.
As I set my sights on GSoC 2026, I’m looking forward to engaging deeply with the project — learning from experienced contributors, understanding the codebase, and making meaningful contributions wherever possible.
I would be truly grateful for any guidance on how best to get started, recommended resources, or potential issues to begin with. Excited to collaborate and learn from you all!
Thank you for the warm welcome in advance.
Best regards,
Soham
Welcome @Sohamsig
Please review - GSoC Ideas: 2026 · pgRouting/pgrouting Wiki · GitHub
It’s still a work in progress but should be enough to give you an idea of what is expected.
Subject: Clarification on my previous PRs (Task 4) of the Intent of application
Hi Vicky Vergara, robe,
I wanted to clarify why I closed my last two PRs from Task 4: Get Familiar with C++. Both PRs were showing 41 files changed instead of just my intended .clang-tidy commit.
This happened because my branches weren’t truly “clean” — they included extra commits from develop/main in addition to my change. Git included these extra commits in the PRs, which caused the unexpected file changes.
I will create a new branch based on the latest upstream develop, cherry-pick only my .clang-tidy commit, and open a clean PR that shows only the intended changes.
Thanks for your understanding!
Best regards,
Soham
I hope you are doing well. I am excited to share that I have completed all the tasks for the GSoC pgRouting application:
  • Intent of Application
  • Experience with GitHub & Git
  • Local Build of pgRouting
  • Familiarization with C++
  • Exploration of pgRouting functionalities
I have also started drafting my proposal according to GSoC guidelines, documenting all relevant issues, pull requests, and screenshots.
I am eager to contribute actively to pgRouting by exploring new features, fixing issues, and improving documentation. Any feedback or guidance on next steps would be greatly appreciated, as I am committed to making meaningful contributions.
Thank you for your time and support.
Best regards,
Soham Babrekar
Hi maintainers,
I wanted to share an update on my PR #3006. I’ve rebased it on the latest develop, aligned it with the recent .clang-tidy changes (by enabling cppcoreguidelines-use-default-member-init as suggested), and all CI checks are now green.
Please let me know if any further changes are needed from my side.
Thanks!
Hi @cvvergara,
My PR #3006 was closed and I understand the CI issues that were pointed out.
I’d like to continue improving my older PR #3003, and I will make sure to carefully double-check CI results and address any warnings before pushing further updates.
Please let me know if that’s fine.
Thanks for your guidance.
Hi @Sohamsig
The PR’s that were closed count for the task4, for GSoC purposes you are OK.
But from pgRouting point of view:
Sure thing, you can start all over if you want and make another PR.
This time try to make the PR when you are sure that everything is OK.
Start working by doing
git fetch upstream
git checkout upstream/develop
git switch -c the-new-branch-name
If you didn’t finish the work and continue on another day or just before making the PR
git fetch upstream
if you see that the upstream/develop had changes do the rebase
git rebase upstream/develop
and fix conflicts if any
Regards
Vicky
Thank you for the clarification and detailed guidance.
I will start from the latest upstream/develop, carefully reapply the changes, and open a fresh PR once I’ve verified that all checks pass and the code is fully aligned with the project guidelines.
I appreciate your feedback and the opportunity to improve.
Hello pgRouting Team,
I have prepared my GSoC Proposal and submitted it as per the instructions. i would really appreciate any feedback or suggestions if there are any improvement needed.
Best Regards,
Soham Babrekar.
Hi @cvvergara, @robe
I hope you’re all doing well.
I’m preparing for GSoC 2027 and have been contributing to the pgRouting project for the past two years. I enjoy working on the project and want to continue improving my understanding of the codebase.
During a previous GSoC cycle, I explored the Maximum/Minimum Cycle Ratio algorithm using the Boost Graph Library. It made me more interested in graph algorithms and how they’re implemented in pgRouting.
As I prepare for GSoC 2027, I’d really appreciate some guidance from the maintainers and experienced contributors.
  • Are there any areas of the codebase (such as algorithms, testing, documentation, performance, or PostgreSQL/PostGIS integration) that I should focus on?
  • Are there any graph algorithms or optimization techniques that would be especially useful to learn for contributing to pgRouting?
My goal over the coming months is to keep making meaningful contributions, improve my understanding of the project, and prepare myself to contribute to larger features in the future.
I’d really appreciate any advice or suggestions.
Thank you!
I think the first place to get started is reading this - GSoC Ideas: 2026 · pgRouting/pgrouting Wiki · GitHub
In particular the pgRouting Workshop. I think that is the area we need the most help with at the moment. You can do pull requests here: GitHub - pgRouting/workshop: Source, data and docs for the pgRouting workshop · GitHub
