GSoC 2026 Week 11 Report: Implementation of Make Biconnected Planar and Make Maximal Planar Algorithm to pgRouting
Mohit Rawat
Github id: Mohit242-bit
Mentors: @cvvergara, @robe
Organization: OSGeo / pgRouting
OSGeo Profile: OSGeo Profile Link
Project Wiki: Github Wiki Link
Repository: Repo Link
This is my eleventh weekly report of Official coding period for GSoC 2026
What did I get done this week? (3 August - 9 August)
This week was focused on a major architectural migration to align both the makeMaximalPlanar and makeBiconnectedPlanar implementations properly with pgRouting’s modern core architecture (the shared coloring_driver + coloring_process pattern). I also added comprehensive pgTAP tests and prepared the Boost 1.80 Proof-of-Concept CI homework.
  • Architectural Migration: Successfully implemented makeMaximalPlanar and refactored makeBiconnectedPlanar to use the unified core coloring_driver / coloring_process. I deleted the old custom boilerplate files (4 files deleted, 346 lines removed). Both algorithms now integrate cleanly as cases inside src/coloring/coloring_driver.cpp.
  • Logic Optimization: Moved edge sorting by (d1, d2) cleanly inside the respective algorithm .hpp files, removing stray std::sort calls from the driver loop.
  • pgTAP Testing: Added deep pgTAP edge case testing (pgtap/planar/makeMaximalPlanar/edge_cases.pg). Tested empty graphs, self-loops, path graphs, disconnected graphs, and non-planar K5 rejection.
What do I plan on doing next week? (10 August - 16 August)
Next week, I plan to:
  • Open PRs for the Boost Proof-of-Concept branches and report the CI results.
  • Finalize the image update in the maximal planar documentation.
  • Prepare the final, polished PRs to pgrouting/develop.
Am I blocked on anything? No
References:
1] Link to detailed wiki page
2] Link to github repository
3] Link to pull requests : [1] and [2] and [3]
