GSoC 2026 Week 11 Report: Implementation of Maximum Weighted Matching Algorithm to pgRouting
Mayur Galhate
Github id: mayurgalhate
Mentors: @cvvergara, @robe
Organization: OSGeo / pgRouting
OSGeo Profile: OSGeo Profile Link
Project Wiki: Github Wiki Link
Repository: Repo Link
Hello everyone,
This is my eleventh weekly report of Official coding period for GSoC 2026
Week 11 Report (10 august ~ 16 august)
What did I get done this week?
  1. Applied the same consolidation approach demonstrated by @cvvergara for pgr_coreNumbers, this time to pgr_maxWeightedMatching. Since pgr_maxWeightedMatching returns IID_t_rt (from_vid, to_vid, cost), coloring_process.h could not be reused because it supports II_t_rt.
  2. Switched pgr_maxWeightedMatching to the appropriate shared IID_t_rt process/driver architecture and removed the function-specific process/driver implementation where it was no longer needed.
  3. Since no existing process/driver pair was suitable for IID_t_rt and maximum weighted matching, added the required process/driver integration with a Which switch and a MAXWEIGHTEDMATCHING case, following the existing pgRouting driver structure.
  4. Added MAXWEIGHTEDMATCHING to the enumeration and get_name(), and repointed pgr_maxWeightedMatching.c to call the new process function.
  5. Updated pgRouting-introduction.rst and release_notes.rst with pgr_maxWeightedMatching.
  6. Resolved merge conflicts and synchronized the changes with the latest branch.
Boost Proof of Concept – PR #634
  • Opened the first Boost version PoC branch for pgr_maxWeightedMatching to start testing Boost version compatibility in CI.
  • Updated wiki page can be found in [1]
  • The pull request can be found in [2]
  • The pull request can be found in [3]
Am I blocked on anything?
  • No
References:
Thank you,
Mayur Galhate
