We noticed that having a NAMESPACE parameter in a WFS request causes an HTTP 403 error. This happens on a GeoServer instance where I don’t have direct access, so I don’t exactly know how it is configured. I can give some recommendations to the administrator, though. This problem occurred when they upgraded their GeoServer instance to version 2.25 from a previous maintenance version.
The following request fails with “403 Forbidden” error:
GET https://www.company.com/geoserver/customer_c/wfs
?service=WFS
&version=1.1.0
&request=DescribeFeatureType
&typeName=customer_c:Data
&NAMESPACE=xmlns(customer_c=https://company.com/geoserver/customer_c)
If I omit the NAMESPACE parameter or remove the customer_c= prefix from the parameter, the request succeeds. Both requests have the same Authorization header.
Could this be a configuration issue with workspace permissions or could it be a GeoServer bug?
Why would you pass that namespace parameter if it works without? Are you using the same uri as in the Geoserver catalog? It isn’t necessary the url of the web site. You would see that from the resulting xml without that parameter.
The name “customer_c” should be OK, but I would still test if the issue is the same with “customerc”. I would also check if the company has something in front of Geoserver and if the 403 Forbidden error comes before the request is reaching Geoserver.
I’m using FME 2022 to connect to the WFS api and for some reason it adds the NAMESPACE parameter to the request and I can’t affect to that. There’s a new option in FME 2024 to omit the namespace parameter, but currently I’m stuck to 2022.
Yes, it is the same.
That is indeed a question to be asked. Actually the 403 HTTP response in this case is different kind than the normal 403 responses by GeoServer. I’ll look more into this.
I believe the proxy base URL is misconfigured to use http:// instead of https://, which is used in the namespace. We’ll try changing that to see if it helps.
You mentioned that this might have something to do with External Entities Resolution security. I don’t understand what (external) entity is requested here and possibly blocked. The documentation states: “This is most commonly seen when the XML request provides the location of an XSD schema for validation.”. Does the namespace parameter have something to do with the schema location?
I still don’t quite understand what the namespace parameter is actually doing. In my test environment, it doesn’t affect the DescribeFeatureType responses in any way. I have tested with both a default workspace and a restricted isolated workspace.
I got my process working by selecting 2.0.0 as a used WFS version in the FME WFS Reader.
FME forms then the following url for DescribeFeatures request:
I still don’t know/understand where the problem actually was. It might even be somewhere outside GeoServer. However, it works now, and my working hours are limited, so I can’t dive that deep into this.
