The documentation mentions pulling “docker.osgeo.org/geoserver:2.27.x”, but that’s just a placeholder. I’ve tried “2.27.0”, “2.27-SNAPSHOT”, “main”, and other tags but to no avail. Which tag do I need to use? I need some community plugins so I need geoserver nightly.
Welcome to the forum. I do not think that is a placeholder? For blog post I tested the following:
docker pull docker.osgeo.org/geoserver:2.27.x
docker run -it -p8081:8080 docker.osgeo.org/geoserver:2.27.x
However that does not appear to be working today:
Error response from daemon: manifest for docker.osgeo.org/geoserver:2.27.x not found: manifest unknown: manifest unknown
Looking at instructions that appears correct.
Testing an earlier version is working for me:
docker pull docker.osgeo.org/geoserver:2.26.x
docker run -it -p8080:8080 \
--env INSTALL_EXTENSIONS=true \
--env COMMUNITY_EXTENSIONS="ogcapi-features" \
And I can see the community module on the welcome page:
And in the module rest/about/manifest
So the question is why is 2.27.x not working?
Checking geoserver-release-docker #1325 [Jenkins] it has built recently:
Started by upstream project geoserver-main-nightly
(geoserver-main-nightly [Jenkins]) build number 1966
originally caused by:
- Started by upstream project geoserver-main build number 2100
- Started by an SCM change
Checking the logs we can see:
Login Succeeded
docker push geoserver-docker.osgeo.org/geoserver:2.25.x
That is … not so good!
Bug report: GEOS-11572 Docker main published as 2.25.x
So I understand that a recent build mistake pushed 2.27.x as 2.25.x? Indeed, that’s not ideal. However, running 2.25.0 runs, well, 2.25.0, and I still can’t use community modules. Do you have suggestions that I can follow while 2.27.x is getting fixed?
Yes, please run 2.26.x which is the nightly build of the stable series.
I used it in the examples above (so you can copy and paste).
A few heads up for folks who found this thread and want the full solution (these conclusions are based on my local testing, I’m not a GeoServer expert):
- 2.26.x, where ‘x’ is the character ‘x’, is a nightly build. 2.26.x, where ‘x’ is an integer, is stable, and “COMMUNITY_EXTENSIONS” will be ignored.
Thanks for your help, Jody.
I am not sure I understand the second point about /opt ? Can you explain what happens …
I was about to write that the container didn’t seem to install COMMUNITY_EXTENSION when the /opt/geoserver_data
folder is already initialized, but I couldn’t reproduce what happened. It was probably a misconfiguration on my part, so I’ll go tweak my previous answer.
I was able to fix the issue with 2.27.x nightly not working.
GEOS-11572: There is a small fix to correct the documentation example still wanting review.
But the important thing is you can now try out the latest OGC API - Features extension:
docker run -it -p8080:8080 \\
--env INSTALL_EXTENSIONS=true \\
--env STABLE_EXTENSIONS="ogcapi-features" \\
