Hi, if I want to add a discourse tag, for a new post - for example spatialite - how can I do it?
Is there a procedure to request the addition of a new tag?
Thank you
Thank you
Ideally just put in a ticket in our tracker OSGeo under Sysadmin/Discourse.
@andyborruso I upped your trust level, so you should be able to create tags now. I think you can create one when you create a post if you have the right level.
I opened a ticket
https://trac.osgeo.org/osgeo/ticket/3168#ticket
Thank you
Done
