How to clip image...
Hi, please suggest me...
I'm new user. I have an image on GRASS as a big picture. I'd like to
ask you how to clip and copy an image in some part by using grass
command.
Thanks very much,
command.
Simply set the region using the g.region command, to that part that you
wnat. Then run g.copy and only that bit within your set region will
appear in the new file.
Terry Duell
