HP DesignJet 650C driver
>Where can I find a driver for a HP DesignJet 650C? I need something to
>paint to a large format inkjet plotter ... I have looked on moon, and
>on baylor but I can't seem to find one... Will I have to write one
>myself?
>Richard Nairn
>Geological Survey of Canada
>** Email ren@spans.gscc.nrcan.gc.ca **
>** nairnr@cadvision.com **
Richard:
        I may not understand this correctly, but I think all you need to do
is copy the postscript file (produced in ps.map) to a postscript compatible
plotter. GRASS does not print directly to a plotter, so there are no
special drivers required. The HP site has scads of different drivers
available for downloading under their product support page. Please correct
me if I am wrong. Hope this helps.
Shawn Francis
Either that, or I don't understand the process completely. :slight_smile: Where
do you specify the page size then? How does ps.map know that I want a
plot that is 36" wide. I know I can specify a scale, but sometimes
that gets mangled...
Ok, I just found the ps.select and how to specify the page size.. I
will see if that solves my problem... Wish I knew what FM to RTFM :slight_smile:
Richard Nairn
