HTTP OPTIONS request fails after upgrade to 2.26.1
I am trying to upgrade our instance of GeoServer from 2.24.2 to 2.26.1 and when testing our REST endpoints the preflight OPTIONS request is failing.
E.g.:
In browser it seems to be a CORS error but the Tomcat (9.0.97) web.xml already contains allowed methods:
<filter xmlns="">
    <filter-name>CorsFilter</filter-name>
    <filter-class>org.apache.catalina.filters.CorsFilter</filter-class>
    <init-param>
      <param-name>cors.allowed.origins</param-name>
      <param-value>*</param-value>
    </init-param>
    <init-param>
      <param-name>cors.allowed.methods</param-name>
      <param-value>GET,POST,OPTIONS</param-value>
    </init-param>
    <init-param>
      <param-name>cors.allowed.headers</param-name>
      <param-value>
        Content-Type,X-Requested-With,Accept,Origin,Access-Control-Request-Method,Access-Control-Request-Headers,Authorization,Referer,
        ticket,Cache-Control,Accept-Encoding,Accept-Language,Connection,Host,Pragma,Sec-Fetch-Dest,Sec-Fetch-Mode,Sec-Fetch-Site,User-Agent
      </param-value>
    </init-param>
    <init-param>
      <param-name>cors.exposed.headers</param-name>
      <param-value>Access-Control-Allow-Origin</param-value>
    </init-param>
    <init-param>
      <param-name>cors.preflight.maxage</param-name>
      <param-value>10</param-value>
    </init-param>
  </filter>
When testing in Postman I am getting this error:
<h1>HTTP Status 500 – Internal Server Error</h1>
    <hr class="line" />
    <p><b>Type</b> Exception Report</p>
    <p><b>Message</b> Cannot invoke &quot;java.util.Collection.iterator()&quot; because &quot;attributes&quot; is null
    </p>
    <p><b>Description</b> The server encountered an unexpected condition that prevented it from fulfilling the request.
    </p>
    <p><b>Exception</b></p>
    <pre>java.lang.NullPointerException: Cannot invoke &quot;java.util.Collection.iterator()&quot; because &quot;attributes&quot; is null
	org.geoserver.security.filter.GeoServerSecurityInterceptorFilter$AuthenticatedAuthorizationManager.vote(GeoServerSecurityInterceptorFilter.java:83)
	org.geoserver.security.filter.GeoServerSecurityInterceptorFilter$AuthenticatedAuthorizationManager.check(GeoServerSecurityInterceptorFilter.java:113)
	org.geoserver.security.filter.GeoServerSecurityInterceptorFilter$AuthenticatedAuthorizationManager.check(GeoServerSecurityInterceptorFilter.java:46)
	org.geoserver.security.filter.GeoServerSecurityInterceptorFilter$AffirmativeAuthorizationManager.check(GeoServerSecurityInterceptorFilter.java:198)
	org.geoserver.security.filter.GeoServerSecurityInterceptorFilter$AffirmativeAuthorizationManager.check(GeoServerSecurityInterceptorFilter.java:173)
	org.springframework.security.web.access.intercept.AuthorizationFilter.doFilter(AuthorizationFilter.java:95)
Can anyone please advise what is needed to configure for the preflight OPTIONS requests to work again?
known issue, due to an upgrade of Spring Security.
A PR to fix it is being evaluated as I type this mail:
https://github.com/geoserver/geoserver/pull/8087
Hi, so I tried to build the current 2.26.x branch, take the gs-main jar and replace the 2.26.1 gs-main, but now I am getting 401:
Regular GET requests with bearer token auth still work ok.
Am I still missing something?
Had a quick check with Joseph, indeed to avoid the 401 the OPTIONS method should be listed here:
Needs to be added to that list, and a test written, so that it cannot regress again.
Anyone here with time to do it and issue a PR?
Hi, I just wanted to ask if any developer is going to add this fix with OPTIONS or if it´s better if we try to create the PR with this change.
Always assume you’re better off submitting the change for yourself, it’s very unlikely that someone will take hours away from the weekend to solve an issue you have… if anything, they will touch something that bothered them, if they just don’t stay away from the computer at all, and be done with it.
See also this guide:
You might be intersted in this one:
(thanks to DLR for supporting the fix).
Ah you made the fix! Excellent, thank you :slight_smile:
